igotanxj
- Citrus heights
Shouldnt make a difference, ring/pinion are the same AFAIK. If its true, cool, but i'm still not holding my breath. Something like this pops up at least 3 times a year here.Website only mentions 27 spline count size, not 29....
if i can remember correctly, the reason nobody made a 4.88 for the 8.25 is the pinion size, it gets smaller, and smaller, the higher numerically you go in gears.
if you searched, youd find pictures of said pinion.
if your going higher geared, chances are you run bigger tires and are harder on the jeep.
apparently nitro gear and axle doesnt have a website, and if they cant get a basic website up, i sure wouldnt trust them to make gears. theyre probably chinese crap(chinese buisnessmen doesnt care how long your 4.88's last after you buy them)
theres a reason people only use gears from certain companys... good luck. keep us updated on your chinese running gear.
uh huh
With 2 mins of searching i found a short little paragraphs about them.
"NITRO gears are manufactured using state-of-the-art CNC Machining processes, and the highest quality 8620 forgings. Special heat treating and lapping processes ensure long lasting, quiet running, and a smooth installation every time."
-thats the same kind of steel that superior and yukon advertises
From what I found it seams to be Just Differentials private brand. Smells like chinese to me.
