I was curious if the injectors were the same in a 4.0L as the 2.5L
After looking at parts sites and the jeep catalog pdf I have, it looks like there are different part numbers for each. Not sure what the diff is, maybe the pounds per hour rating.
im pretty sure that the lbs are different. and if your looking for a stock injector then i would not buy these. if your motor is completely stock then these are probably not the injectors you are looking for
Look at the color of your stock injector tops. They will fit, but they may not be the right flow. I know my buddy's TJ 2.5L has grey tops which are 23lb. IIRC, you should be looking for 21lb, but don't quote me on that.
yes they will. everyone that i have sold them to so far has put them on a stock engine. i dont think i have sold them to anyone with a built engine yet. i had a set on my stroker. but i was going to buy a set before i bought my stroker for my stock 4.0.
