tow hook
- western pa
my basement is over full these gotta go
xj stock pitman arm
xj hood release cable
dayco preety new serp beltfor a 98"
good year gator back serp belt for a 93" low miles
master cylinder 98" xj
rustys off road cold air intake, needs filter. spector filters @ auto zone will work.
2" extended front xj bump stops
2" extended rear xj bump stops
93" 4.0 pcm
xj muffler and tail pipe
96" master and diap. great up grade for all earlier xjs with bigger tires
set of 4 center caps off a 97" and later xj
3" steel lift blocks 2.5" wide
2 long side front axle shafts,tj, xj, mj,zj
98 a/c compressor
mopar p/s pump and res. bottles
ipf 4x6 rear back up lite with all wires
other stuff
2" yj front or rear axle mounted bump stops
wj 99-04 grey rear cargo cover
k &n air filter for stock air box on a 4.7 99-04 wj
wj brake booster ( double diap ) and master
tires
new 285/76/16 adventuro mud tire
super swamper iroc radial 33x 13.5- r18 19/32 tread
make an ofter on all above items
I live in western pa, can ship above items, tires maybe pricey. thanks brian
xj stock pitman arm
93" 4.0 pcm
98 a/c compressor
other stuff
tires
