Replaced the trackbar on the '01 XJ and found the bolt I needed. The OEM bolt had worn to a sloppy 9mm on the shaft and wiggled around in the bushing sleeve.
I didn't want to reuse the old flag nut but because of the difficulty in getting a wrench in there I removed the staked prongs on the nut from the "flag" with a dremel, then JB welded a new nut in.
