High Steer Sway Bar Mounts - Clayton Off Road
Clayton Off Road
Clayton Off Road
East Haven CT
High Steer Sway Bar Mounts From Clayton Off Road
Here's another product from our WJ knuckle conversion project. This mount creates the clearance you need on the passenger side sway bar mount for the steering drag link. Check out some pictures of it below.
Getting the mount lined up:
Adding the gusset:
Gusset welded, and installed:
See the whole album HERE.
Alex
Marketing Director
Clayton Off Road
What steering setup is this designed around? Heims? Offset TREs? Just curious as I run a similar bracket from another source and had to modify it to make it work around heims.
Regardless, your WJ swap stuff is looking pretty nice, glad to see another manufacturer starting to make parts for it.
Edit: Just saw your steering thread. Looks like WJ TREs but you haven't finalized yet...
as always - stellar fab work you guys.
