Jerm S.
- Northern Utah
I'm in the middle of doing a front axle swap on my 88' xj. i'm replacing the D30 with A D44HP. I have the rockrawler LA lift and have decided to change the design a little. I would like to know what you all do when you make your long arms. do you use a shorter arm that connets to the longer lower arms like rock krawler does or do you use something like a ford radius arm. and what are the pros and cons to all the setups. some pics would be great.
Tia
Jerm s.
Tia
Jerm s.
