Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor's Specials
Old June 4th, 2009, 09:44
AJsArmor's Avatar
AJsArmor AJsArmor is offline
NEW Tire Carrier Hinge DIY Kits!!!
FINALLY!! Not satisfied with the quality of the traditional spindle/bearing hinge setups, we set out to design our own tire carrier hinge that we would be trust in 100% for our own products. The spindle/bearing setups are known to crack and snap off at complete random, not something we'll ever use on our products again.
Quality comes at a price but we've done a lot to keep it as low as we can. Introductory price of $95, can ship to anywhere in the US for $13 using flat rate USPS Priority mail. We have 4 available for immediate shipping and will have 20 more ready to ship next week.
Throughout the process of design we kept quality in mind to give customers the absolute best product possible. So here's what's included!
  • CNC laser cut top/bottom plates and 3 supports
  • precision machined bearing tube with grease zerk and dust cap
  • tapered roller bearings and oil seal
  • threaded rear supports with socket head cap screws
  • MASSIVE 1" shoulder bolt with 3/4" threads
  • bellville lock washer and 3/4" grade 5 nut
ASSEMBLED
BOTTOM SUPPORTS
Old June 4th, 2009, 09:46
AJsArmor's Avatar
Re: NEW Tire Carrier Hinge DIY Kits!!!
Some more pics, having the plast CNC laser cut makes for an absolute precision fit!
Showing the bottom bearing in place with spacer.
Oil seal set into place but not pressed in.
Old June 4th, 2009, 11:09
mn-xj mn-xj is offline
Got mine ordered.
Thanks AJ
Rate This Thread:
tire carrier hinge nicksjeep Advanced Fabrication and Engineering 32 June 4th, 2009 10:31
Tire Carrier Hinge hairyharry155 Modified Tech Discussion 5 November 12th, 2008 21:29
fabbing tie carrier --need a tire carrier hinge ?? VegasAnthony Modified Tech Discussion 4 March 20th, 2007 18:03
tire carrier hinge joshbish Modified Tech Discussion 18 February 20th, 2005 14:07
