Old October 25th, 2008, 02:06
SurfXJSnow's Avatar
SurfXJSnow SurfXJSnow is offline
My BFG 31X10.50X15's measure 29 inches tall?
As stated above... my 31's only measure 29 inches tall and they are brand new... Whats with this?
They read 31X10.50X15 on the side. Odd.
Old October 25th, 2008, 02:15
redneckguy0404's Avatar
redneckguy0404 redneckguy0404 is offline
Re: My BFG 31X10.50X15's measure 29 inches tall?
tire manufacturers cant read a tape measure apparently, happened to my buddy on pro comps, if you want true size its hard to find, interco is pretty good, guess they make them the right size since they wear like shit!!!!!!!!!!!!!!!!!! but grip like a demon comin out the grave
Old October 25th, 2008, 03:08
99xj4x4's Avatar
99xj4x4 99xj4x4 is offline
Almost all radial tires are smaller that what it says on the side of the tire. Each co is a little closer or farther off. Its normall... You didnt get ripped off, calm down.
Old October 25th, 2008, 03:21
stumpXJ stumpXJ is offline
summitracing.com usually tells you the actual size as well as the advertised size. I used this when I was shopping for tires.
Old October 25th, 2008, 04:12
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Wheel size is also a determining factor of actual size. Not everybody runs the same wheel, and not every type of wheel will give you same height with the same type of tire.
Also air pressure is a factor as well. You certainly aren't running the tire at the max pressure that it can handle. You're probably in the 25-35 range. The lower the pressure, the shorter the tire is.
All of these are factors that can tweak your tire size. My 32's measure out to 30's so you're right on the same scale as me apparently, don't be concerned.
Old October 25th, 2008, 08:06
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
BFG's measure smaller than advertised. Firestones measure larger than advertised. My Dayton Timberlines (same as Firestone Destination MT) are 31's and measure almost 32". The BFG MT's that I'm buying are 35's but are closer to 34".
Every tire manufacturer is different.
Old October 25th, 2008, 09:34
tbburg's Avatar
tbburg tbburg is offline
The 31s I had measured right at 30".
29" sounds a little short. Are you measuring from the ground to the top or the true diameter?
I have a set of 30X9.50s that were right at 29 1/4" new.
Old October 25th, 2008, 10:09
JNickel101's Avatar
JNickel101 JNickel101 is offline
How about the width on tires? That usually pretty accurate?
Not trying to hijack, just curious if those BFGs are 10.5" wide, or a little smaller...?
Old October 25th, 2008, 10:12
tbburg's Avatar
The width is less accurate then the height. They measure the width at the widest part of the carcass, not the tread face. Mount a 10.5" tire on a 10" rim, it will measure a lot wider then if you mount the same tire on a 8" rim.
Old October 25th, 2008, 10:21
JNickel101's Avatar
Good to know...could you mount an 11.5" wide tire on a 7" rim? Bad juju for the sidewall?
Old October 25th, 2008, 10:43
tbburg's Avatar
Originally Posted by JNickel101 View Post
Could you mount an 11.5" wide tire on a 7" rim? Bad juju for the sidewall?
Could? yes. Would? no. You'd probably run into some flack at most tire shops if you asked, but there are places that will do it. 11.5" tires are a little too wide for a 7" rim, but if you look around, you'll see them. 'Makes the tire look a little funny. Jeeps really don't weigh enough to cause issues that will tear up the tire carcass. The biggest problem would be handling. The narrow rim would allow the tread face to shift side to side in relation to the rim, and make the steering squirlly.
Old October 25th, 2008, 10:58
NW-ZJ-SCOTT's Avatar
NW-ZJ-SCOTT NW-ZJ-SCOTT is offline
i've seen 13.5s run on an 8" wheel, so i dont see why thats an issue?
Old October 25th, 2008, 11:21
XJfire75's Avatar
XJfire75 XJfire75 is offline
Most run 12.50s on a 8" wide wheel. Same difference in the 7".
More rim protection too. Id do it.
Old October 25th, 2008, 13:06
Crabapple Crabapple is offline
Ran BFG A/T 32/11.50 hard on stock 7" rim for a long time with nothing negative to report.
Old October 25th, 2008, 14:52
98stocker 98stocker is offline
My buddy has 49x21 inch irok's on 10 inch rims. Doesn't lose beads easily...
how tall are you? (lifted 84-96 XJ's) BigOrangeXJ Modified Tech Discussion 2 July 29th, 2006 13:23
4 BridgeStone Dueler M/T's 31x10.50x15's Bolognablake For Sale: Private Party Only. XJ ITEMS ONLY 7 October 2nd, 2004 00:43
5~~ 31x10.50x15's BFG AT + pro comp spare (tires + wheels) witt For Sale: Private Party Only. XJ ITEMS ONLY 4 June 3rd, 2004 16:19
zj coils, how tall? taco502 Modified Tech Discussion 4 November 17th, 2003 16:59
shackles...how tall is too tall? mountaindrew Modified Tech Discussion 1 October 1st, 2003 16:11
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
