Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old March 5th, 2010, 23:47
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
The Stupidist Jeep on the Planet
So its time for me to make a buld thread for my 95 XJ time had come to finally get this build goin, first ill start with a lil history on it
Got it back in high school (circa 2003) from my parents wheeled the crap out of it stock, blew up the d35 got a D44 then installed a 2" BB, got some 30's and wheeled that for a year
Broke the driveplate also rust started hapening so it got taken off the road Feb of 2006, then sold the D44, then it sat in the driveway for a year, i bought parts for a 4.5" lift with plans to run 33's, later in the year i got a sweet deal on some used Clayton LA's and 35" Claws so i bumped up the lift to 6",
Nov of 07 moved to a new place with a small garage, finally pulled the trans to get the broken flexplate out, trans is still out to this day
nothin much changed in the next year it basicly sat due to tight funds, then come Nov 08 i bought a 93 XJ for $500 as a winter beater it quickly got a bb and 33" wheel it like that then stated buyin more goodid like more lift and lockers, the plans were to transfer the parts into the 95 when the 93 was done,
the 93 locked f/r and armored, its actually became a test rig for the 95
well i had a few friends blow up there 30's on 35's so i decided to sell the 35's and go 1 tons
bought a 60/10.25 combo
shortly after i got a set of 38" SX's on Stazworks Double beadlocks with 2" backspacing, its gonna be super wide (like 89")
pics of em mocked up
sold the 10.25 and bought a D70 with 4.88's i belive its out of a late 60's gm bread truck, its getting welded and disc brakes
the 93 was parted out last month im takin the trans from it for the 95
that basicly brings up to date on it
on thurs i orderd a 4.3 Atlas with 1300 flanges, shall be shipped in 5 weeks
i also got brown dog poly motor mounts and block brackets for it
complete plans for it
5" of lift
3 link frt using 2.5" johnny joints
frt 60 fullwith, with 4.88's, lock rite, ruffstuff cover, 35 spline outers and drive flanges
replace rusty floors
plating of frame rails
fullcage
cut 2" out of bottom of doorss adding box tube and boat sides
keep as full bodied as possible
Old March 5th, 2010, 23:51
5spd_xj's Avatar
5spd_xj 5spd_xj is offline
<<the good ol days
Re: Just a Cherokee on tons
here's to getting this thing wheeling before Armageddon
Lemme know if I can help with anything, cause I can't wait to see this thing on the trails
Old March 7th, 2010, 06:18
redneckboarder's Avatar
redneckboarder redneckboarder is offline
sweeeeeeet...im jealous of the aluminum world map thingy tho
Old March 7th, 2010, 07:15
MoparManiac's Avatar
MoparManiac MoparManiac is offline
This will be the most epic build ever.
Old March 7th, 2010, 07:28
asp's Avatar
asp asp is offline
i believe the word "epic" is defined as long and drawn out but also momentus. so yes, this build will be epic.
Old March 7th, 2010, 07:31
foxwar71 foxwar71 is offline
Will the hover converstion be installed, or is there a new secret version in progress?
Old March 7th, 2010, 10:32
offroadman83's Avatar
offroadman83 offroadman83 is offline
Nice...............
Old March 8th, 2010, 09:47
Goatman's Avatar
Goatman Goatman is offline
Epic......referring to the builder, or the build?
Lot's of 1 ton XJ's out there.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old March 8th, 2010, 09:53
Builder.
After seeing how he wheeled a 2" lifted XJ on 33s, I can't WAIT to see him wheel this thing.
Old March 8th, 2010, 15:52
vetteboy's Avatar
vetteboy vetteboy is offline
That is fully 4.5"+ wider on each side than mine.
Are you keeping the front dually width?
Old March 8th, 2010, 16:14
ROBZ95Xj's Avatar
no i got some srw hubs waiting top go on, but the wheels i got have 2"BS so it will sit around 89" in frt
Old March 8th, 2010, 22:58
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
And I thought Rockwell's with 4wheel steer on a Durango was crazy..
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old March 18th, 2010, 16:46
ROBZ95Xj's Avatar
either this weekend or next week im gonna buy some goodies for the 60, plans are..
crosover steering with hydro assist consisting of
Reid Knuckles with arp studs
hi steer arm on pass side(not sure what brand to get yet, sugestions?)
PSC hi volume pump kit
PSC 2x8 Cylinder Assist kit
any thoughts or sugestions are greatly apriciated
Old March 18th, 2010, 23:10
RCman's Avatar
RCman RCman is offline
Life is big block
Are you planning on using the stock location steering arm for the tie rod?
If so, I'd get at least the tie rod mocked up so you can measure the exact travel ram you need. PSC will limit the stroke to exactly the specs you give them so you don't have to mess with it.
If you are going the entire high steer route, get the arms on and do the above first before ordering the ram/pump.
Old March 31st, 2010, 15:49
ROBZ95Xj's Avatar
been getting goodies the past couple weeks
jam nuts ,bolts and tube incerts from Clayton Offroad
Johnny Joints from Summit
Ried knuckles with all hardware from Extreme axle sales
yesterday i ordered some Solid drive flanges for the 60
today i also got the final pieces for the exhaust with will be made up of stock header and downpipe, 2.5" cat 3" Thrush 2 chamber and 3" tailpipe
within the next couple weeks i plan on havin the motor swap in my DD done then i will start throwing parts at the 95, cant wait
Rate This Thread:
Jeeps on Little Planet Pic 4WDlifeform Non-Tech / Off Topic 2 November 30th, 2011 19:36
Blowing Up a $60,000 S.U.V. To Save the Planet buzzbombxj Non-Tech / Off Topic 8 July 25th, 2008 08:19
Planet Audio 12 inch sub Feeler Skwerly SoCal For Sale 0 January 18th, 2008 14:13
Planet Audio Amplifier Opinion blaisetd Non-Tech / Off Topic 3 April 25th, 2007 13:08
The Northeast Association of 4WD Clubs Cleans our Planet for Earth Day! Kejtar Land Use Forum 0 March 21st, 2003 11:55
