Just Differentials
Differentials and Axles!
- Washington State
Nitro Street Billet 9" now available!
Machined in the USA from 6061T6 Billet aluminum with 7075 alloy bearing caps, featuring a load bolt for extreme resistance to deflection, high strength cap studs and designed to accept standard Nitro 9 inch ring and pinion sets and differentials. These will also accept a 10 inch pro-gear set using a different pinion support.
This third member sets the standard for strength, style and durability all while weighing in at 20-30% less than a comparable nodular iron case. It is pictured running a Nitro 3.70 gear set, Nitro torsen style limited slip differential and solid spacer with a forged 1350 yoke. This combo professionally assembled retails for about $2500.00 ready to ship. Other ratios and diffs available.
Call 866 349 6801 or email [email protected] to request a quote on a combo that works for your ride!
