Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > FREE Items. No SPAM
FREE Items. No SPAM If you have something to give away at no cost, post it here. If you post anything that seems like SPAM, it may be deleted.
Old August 8th, 2011, 08:24
ehall's Avatar
ehall ehall is offline
87-95 D35 driveshaft
I have a rear driveshaft for an 87-95 XJ with a 4WD AW4 and D35 axle. This will be a direct fit for any other XJ with those properties. Since the D35 pinion is shorter than the 8.25 and the D44, the driveshaft is too long for those axles at stock ride height, but fits good if you have +3" lift. It won't work at all with 96+ XJ (different transfer case output length), or 2WD (different length), or a manual tranny (different length). FWIW I installed new greasable Spicer u-joints a couple of years ago, and the driveshaft is in good condition overall.
It will fit into a FedEx shipping tube and will cost $15-20 to ship.
my '91 beater rebuild
Old August 8th, 2011, 09:13
ehall's Avatar
Re: 87-95 D35 driveshaft
Here's a pic
Old September 28th, 2011, 11:34
ehall's Avatar
Well I just measured the driveshaft and it shows 31" exactly. It is half an inch longer than the 87-95 AW4 4WD with D35 that I listed here. According to the research I did earlier and the available interchange data, it is for a 93-95 AX15 4WD with a D35.
It will work with an AX15/4WD/D35 at stock ride height, an AX15/4WD/8.25|D44 or an AW4/4WD/D35 with +3 inches of lift, or an AW4/4WD/8.25|D44 with +5 inches of lift.
The AX5 (87-92) is quite a bit shorter than the AX15 so this won't work at all for those. The 2WD drivetrain does not have a transfer case so it will not work for that setup either. And the transfer case output shaft on the 1996 and later XJ is also quite a bit different and this is not compatible with those either.
Old March 3rd, 2012, 16:37
ehall's Avatar
Gone
242 t case with SYE installed and Spicer driveshaft adapter and front driveshaft benulis55 For Sale: Private Party Only. XJ ITEMS ONLY 1 July 28th, 2009 05:58
'96 Driveshaft heyhar OEM Tech Discussion 1 September 17th, 2008 18:32
Need: driveshaft drew and not u South East Chapter 7 June 26th, 2006 19:12
Which driveshaft cardboard Modified Tech Discussion 2 July 6th, 2004 03:31
CV Driveshaft w/o sye kit ASJackman Modified Tech Discussion 8 February 25th, 2004 23:50
