started to run brakelines, running most of the lines that vettboy posted in rcman's thread
the frt im running a tab off the tb bracket then i welded a tab on the housing the line will pretty much float there, i may move the tab back a little so the line dosnt touch anything
That looks a little too "right out there", especially if these guys talk you into jumping it (which will happen). How about a small piece of angle iron welded to the housing, then the splitter block mounted behind it in the horizontal plane? Or maybe a small piece of steel bent in a "U". Weld both ends of the U to the axle, with the splitter bock mounted in the middle. Might need a longer/custom brakeline though.
