ZJ transmission swap.. Now what?
NW-ZJ-SCOTT
TEXAS-JT-SCOTT
NE Texas
97 Zj 5.2..
Transmission swap issues..
I swapped in a ZJ 46re, to replace my perfectly fine 44re..
I used the 5.2 flexplate (internally balanced). And the 46re torque converter, everything lined up..
The jeep starts a little rough, I have a p0320 code for crank position sensor
But the real issue is, it will run just fine in Park, as soon as you shift it into a Gear, Or neutral.. It instantly dies.. If you restart it in neutral, it will run for 1 second and die
I believe this is an electronic issue.. Anyone have an Idea?
Check to see if the converter is staying locked. I had this problem on a ZJ once. A new TCC sensor fixed it.
