Have you measured them to see the length? There are charts available to tell you how much length you would need for each level of lift.
You need appropriate length UCA's to match your LCA length.
Over about 5" of lift, you really need to do some sort of longarm or drop bracket setup though - the geometry at six inches of lift just isn't stable with shortarms, no matter how long they are.
x2. search the forums for a junkyard thread. it states some info about junkyard upgrades, and i remember seeing the rear lowers on the list because they are longer. how much longer, ud have to measure
IIRC they are 2" longer, making them 17.75 or therabout.
I think the concensus is that they are too long for the front of an XJ and too short to be worthwhile for making longarms out of them.
JK control arms look to be 24" AT LEAST - has anyone thought about using them as the starting point for longarms?
