markaboo929
- Mooresville,NC
OK so when you have a gear set the pinion gear will have a marking on the gear face having either like +2 or -1 or some simmular marking on it to tell what optimum gear placement the manufacturer has determined.On the yukon set there is no marking like "+" or "-" it just some other marking.How do you tell what to add or subtract from the nominal shim size on a Dana 44 which is .042" other than contacting yukon as to what their marking represent?:dunno:
I work at a GM dealer as a tech so I am used to using the factory markings to correctly install gears the FIRST time,with little adjustments
IF needed after gear pattern check,or just do it by pattern contact the old fasion way.I just don't like to press off and on still a
pita even with the correct tools.
