YJ Front Coils
YJs are leafs front and rear. If you are talking about TJs, which are coils front/rear, then yes they are a bolt in but IIRC they actually give a 1" drop. If you are looking for lift then V8 grand cherokee coils give 1"-1.5" inch lift but they do ride stiffer.
Chris
I put YJ coils in the front of mu XJ and it lifted it like 1,000,000 inches!
Thats odd, I put YJ coils on mine and all it did was make the Jeep longer and wider.
That's right! I forgot that I put the YJ REAR coils on there and it lifted it. The front ones do as Ray said.
you don't even want to know! Think like HUMMER H2 high!
WHOA!
Seriously!You could try transverse leafs with a really big sway bar,We used to run that set-up once on a Baja 1K rig.
