Except for the yoke which must be changed from 1330 to 1310. Then you will have the problem of the drive shaft being to long because the dana 44 pumkin is larger and longer. Grab the factory air pump if you can because it's hard to find a decient regulator that is accurate at the 5 psi necessary to pressurize the locker. Too much and you may ruin the locker. I just installed one and it went well. I used P.O.R.C (special to rubicon only) gears and setup only needed a pinion shim removed. The inner axels are a bigger spline count so you cant use your old inners as a trail spare.
If you have a ARB compressor allready I do some home work on the regulators. If not call jeepsareus and ask for one rubicon compressor. I realy like the one I have . It's tiny,reliable and you just wire tie it up under the hood. Throw on a toggle switch and run an indicator lamp thru the diff switch and you done.
