YATPSQ (Yet Another TPS Question)
daoshi
DEN, CO, USA
I've searched the forums and haven't found anything specific to my particular issue.
1988 4.0L AW4 XJ 4WD
At first, it seems like a standard TPS problem. Rough engage on start, 'bouncing' shifts between low gears at lower speeds (<35 mph).
So, I figure that either the TPS is hurked or that it's gone out of adjustment.
Plugged in the multi-meter from connector "A" (+) to "D" (-).
Should be about 5 VDC, right? Nope. _15_ VDC. Yes, fifteen volts.
Pulled the connector apart and checked again. Still 15.
Just for grins, checked the "B" to "D" voltage - which is right at 12.5 VDC.
So, the _percentage_ is right, but the voltage is out of whack.
Any suggestions on what is causing the high volts?
You have the multi-meter on the wrong setting?
Check the battery with the meter. Unless your battery is putting out >15vdc, no way the TPS can be at that.
I did both. Multimeter is an "Auto-Ranger" which tested OK on the battery (12.5 VDC) and on several alkaline batteries that I had laying about.
It is "smart" enough that when I reversed the leads, it showed "negative" voltage.
I'm stumped...
