i dont have part numbers, but you want:
- XJ passenger outer TRE (this is the drag link)
- XJ driver inner TRE (this is the TRE at the pitman arm)
- ZJ passenger inner TRE (V8 model, this is the tie rod)
- ZJ driver outer TRE (should be the exact same part number as the XJ TRE at the pitman arm)
you will also need 2 of the adjusting sleeves, you should have 1 on your current drag link.
