I posted this on jeepsunlimited, also.
I'm installing the WJ steering & brakes with flipped TRE's on my 1998 XJ. After much research I have found a reasonably priced 17" wheel & tire option that is suited for this conversion. I've also learned that 16" Jeep Liberty steel wheels will work for the conversion if the TRE's are NOT flipped. They will NOT clear the draglink TRE when flipped.
The wheels I'm using are 17" x 7" steel wheels from a 2005-2007 Chrysler 300, Dodge Magnum & Dodge Charger. The wheels have 4.5" backspacing. The center hole requires mild sanding with a flapper wheel to slip completely onto the XJ/TJ hub. The later model XJ/TJ wheel center caps (flat style) will fit the wheel if you drill 4 small holes for the sheetmetal attachment screws. I purchased a set of new take-off wheels from Wheels Source in Houston, TX for $150 shipped. Here's a link to an ebay auction:
http://cgi.ebay.com/ebaymotors/4-CH...ryZ43957QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The tire I'm using is the BFG T/A KM sized 255/75/17. This is a 32" x 10" mud terrain that is OEM for the 2007 Jeep Wrangler Rubicon. As of this writing, it is available for $109 each at www.tirerack.com.
http://www.tirerack.com/tires/tires...e&partnum=575R7MTAKM&fromCompare1=yes&place=0
Mike
Mike
