*** XJ STUFF *** Tire Carrier, JCR bumper, D30/8.25, Moabs w/ MTRs (TRADES WELCOME)
VAhasnoWAVES
Lake City, Mi
looking for:
15" rims (8-10" wide, lots of backspacing)
ZJ rear disks
ZJ tie rod (V8 specifically, $40 new)
WJ knuckles
located in mount pleasant. all prices are OBO.
call me (walt) anytime within reasonable hours at 757 646 5173.
if i dont answer, be sure to leave a message or shoot me a text.
i will get back to you.
C4x4 carrier. could use new bearings. works fine though. could be mounted to any bumper with a flat, 4" mounting surface. $250 with incomplete bumper, $200 for just the carrier.
http://a1.sphotos.ak.fbcdn.net/hpho...55395829_100001332774399_226174_1146178_n.jpg
http://a7.sphotos.ak.fbcdn.net/hpho...78729160_100001332774399_226175_7835117_n.jpg
http://a6.sphotos.ak.fbcdn.net/hpho...49423546_100001332774399_359839_8361326_n.jpg
JCR front bumper. ties in to the unibody, 14 total bolts. D ring tabs, Receiver hitch, very sturdy, very good fit. $200
http://a4.sphotos.ak.fbcdn.net/hpho...43463780_100001332774399_321171_5361228_n.jpg
http://a2.sphotos.ak.fbcdn.net/hpho...10028470_100001332774399_326266_3985838_n.jpg
http://a3.sphotos.ak.fbcdn.net/hpho...93079865_100001332774399_341891_3919196_n.jpg
Moabs off of a TJ, all 5 rims. great condition. 245/75R16 old style MTRs. 1/4 tread. worn even. no weather checking. one plug i did myself, has held 30 PSI since may. spare is brand new. $600
http://a7.sphotos.ak.fbcdn.net/hpho...552889669_100001332774399_353274_677301_n.jpg
http://a6.sphotos.ak.fbcdn.net/hpho...36223004_100001332774399_353273_2370274_n.jpg
D30 and 29 spline 8.25. pulled from my manual cherokee, has 3.07 gears. pinion bearings and seals are fine. no bend bracketry. D30 is missing knuckles, unit bearings, and shafts, i have some rotors and calipers you could have as well. rotors might be able to be turned, i wouldnt put money on it. no idea if the calipers work, could be used for a core. 8.25 is complete, drum to drum, good working order. about 150k miles on them both. $50 each, $75 for the pair.
http://a4.sphotos.ak.fbcdn.net/hpho...13597_100001332774399_580717_1301397897_n.jpg
