XJ rear quarter armor
jeffreylane
Memphis, TN
ORFab rear quarter panel armor for jeep xj. Wheel opening has been opened up some (cut) as they were originally on a stretched xj. You can see in the pictures how they look on a non stretched xj, as that is what they were on last. There are some grinder marks by some of the bolts that you can see if you look at the pictures close. These are strong, and will support the weight of the XJ up against a tree. The rail also helps to save the back side windows. $75. Located in Memphis, TN.
901.270.3364
Sent from my SM-G930P using Tapatalk
I'll take these but it might be awhile before I'm back in Memphis. I'm originally from there and travel back to see family. I'll hit you up when I'm headed back down if you still have them.
