XJ paint codes
Ken M
Anchorage
I'm a longtime owner of a '93 XJ Cherokee "Country." I'm looking for a paint code chart or help with the codes I have. The car is a sort of turquoise with a pale gold trim. I think I saw it referred to once as teal and champagne. There are a bunch of 3-letter codes on the firewall plate in addition to the VIN. I assume 2 of them are paint codes. They are NHM, END, ARX, CUF, HGD, JPA, LDB, MWG, A13, APC, PQ2, QV4, & DGB. Any help would be much appreciated.
Take a picture of your plate and post it. (you can block out the vin if desired). The position of the code determines if it's an exterior primary color, exterior secondary color, trim code, or other spec.
Here are the codes on my data plate in their approximate locations:
NHM END
ARX CUF HGD JPA LDB MWG
A13 DGS75001 XJJL72
APC PQ2 QV4 Q7Y6 ERH
DGB U 1J4F.......
So PQ2 and QV4 should be the colors.
PQ2 = Turquoise (not Teal)
QV4 = Champagne
Q7Y6 should be the interior trim code. (have no idea what this decodes to)
ERH = Engine Code (4.0L, should be no surprise)
DGB - Transmission Code (4 sp auto, also no surprise)
U = Market Code (could be U, C, B, or M)
1J4F.... is your Vin (but I guess you knew that)
