XJ factory tow hook set
1990JEEPXJ
San Diego
like the title says, i have a full set of factory tow hooks with all the brackets and hardware. you would only need two 1/2" x 3.5" bolts for the last hole on each bracket. i also tied both hooks together with a piece of 1/4" flat bar so that they would resist bending when being pulled to the side.
$20
Chip clip is first in line and going to pick them up Saturday if everything works out. I will update the thread as needed.
