M mustangconv85 NAXJA Forum User Location Nanaimo, BC Jul 19, 2007 #1 Does anyone know if these gears will work in the XJ D44 http://www.ringpinion.com/ProductDetails.aspx?ProdID=3295
M MisterFubar NAXJA Forum User Location Home Jul 19, 2007 #2 I bet Randy's could answer that question for you. Anyway, they should work as long as you have a 3.73 and down carrier.
M mustangconv85 NAXJA Forum User Location Nanaimo, BC Jul 19, 2007 #3 thanks i'm not buying from Randys a local guy has 2 sets he is selling for a decent price just wanted to make sure they will work before i buy a set
Frank Z NAXJA Forum User Location Colorado Springs Jul 20, 2007 #4 Yes they will fit as long as you have the correct carrier for the gears. Dana44 carrier break is 3.93 and up (numerically higher).
X xjbubba NAXJA Member # 1524 Location santa barbara, ca Jul 20, 2007 #5 Says right in the add that they fit XJ D44s.
pierceME311 NAXJA Forum User Location FL "the trailer park of the nation" Jul 24, 2007 #6 Did you need 4 people to help you read the ad? It says to use the 3.73 and down carrier and it will work, it will save you the cost of buying an new high ratio carrier. A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
