XJ axle swap into TJ
beakie
Ontario, Canada
I am selling my built up D30, and a guy interested wants to know how "easy" it will swap into a TJ.
upper mounts are the same, lowers are new, but same position = all good
coil mounts are about 1" behind stock (moved axle 1" forward) = should be ok
steering is all custom with high-steer bracket from blue torch, and a ruffstuff over the axle trac bar mount = should still be ok
driveshaft length should be ok = all good
the trac bar at the frame is heim (all steering is) and I know his won't bolt up, but would my frame mount fit onto his TJ? = this is the main concern
so any other thoughts on possible problems, or solutions to those I brought up?
thanks
