WTB: Sway bar discos needed
CHUGLYxj
Ephrata, PA
I need a set of sway bar disconnects for 3-4" of lift on my XJ. Or a set of mounts for the discos on the swaybars. I had parts assembled to build a set but have managed to loose all the mounting hardware.
Dude, Rough Country is having a 15% off sale this month and you can pick up there discos for like $40 shipped! For a 3" lift you'll have to cut 1 inch off the center bar section but if you look at them, you'll see it's no big deal at all, 30 seconds with a grinder and a few minutes with a drill for the new pin hole and you'll be gravy baby. I know they're not considered to be the best but they work fine.
I have a set that you can have for $20. They're the RE disco's. Are you going to fall crawl?
