WTB- shims, wheels, front drive shaft
I have some Al, and Fe shims @ ~5 degrees. Also some 2.5 - 3 degrees aluminum shims. The steel shims are nice, as are the smaller Al ones. The other Al shims are well used.
Was just reading your thread. The crappy Al ones were on my rig with well used 3.5" RE springs, and a 1/2 to 1 inch lift shackle, and worked great as far as rear vibes worked. They should fit the centering pin on the RE leafs also. I'll bring them to castle rock this sat., you can have them for jeep karma.
