Rambopants
- VA
Bad Fuel pump, Injector or Fuel Pressure Regulator? I have a new Map,O2,TPS, IAC. TPS is adjusted right. Also put a new connectors on the Jeeps wireing Harness that connects to the TPS. Checked and Cleaned the IAC and TB 16,000 times. No Vac leaks and re-spliced and Fastend my Engine gounds and ground strap. Same probelm....Start the Jeep it will start fine and Idle right. Turn it off and back on and Its shoots to 3,000 and sometimes goes down but most of the time it stays and i have to slam it into R and it goes down but even then it won't go all the way down. Im out of ideas.
