yossarian19
- Grass Valley, CA
I've read up on the benefits of a full circle clip on the Dana 30 U-joint. It keeps the u-joint bearing caps in place even under high strain, which is crucial. Lots of failures happen because the yokes distort a small amount, the cap gets spit & kabloowey. Junk is broken.
I'm not sure it's worth finding the clips & grinding the shafts before I reassemble the shafts I've got on the bench, though, since I'm only going to run 30s or 31s.
Thoughts?
Thoughts?
