jeep.kevin
- Edwards AFB CA
ok...
ill try to make sense of this. ive been reading a tons of threads and trying there fixes. but none of the threads list their fixes.
right now the only way my jeep will run is if i jumper the 4th and 3rd relay from the firewall. also, when i turn the key to "RUN" i dont get the 2-3 second fuel pump prime.
1. tried to jumper the white fuel pump ballast.
2. checked and re checked the CPS
3. ran the entire wiring harness from the relays back to the ecu to check for breaks (love the ghetto factory splices i found)
4. bought 4 new relays and put em all in and same problem
having done all these checks makes me think it is the ECU. like its not giving out the signals to initiate the relays and start the whole starting sequence.
does the factory dash clock not being installed have anything to do with this?
last, i am electrically challenged and had recently wired in 4 new hella lights, and also did some welding on the chassis without knowing it could mess up anything.
please help, i'm at wits end here. :wow:
