SeansBlueXJ
- Plainfield Township, PA
Ok, this may be a Death Wobble issue, or not. I couldnt find sufficent info searching that I havent already been though. so here I am positing for ideas. I recently lifted my truck (2000) 2''. Aside from extending the sway bar links everything else is stock. I swapped in a yj crossover stering into the jeep to eliminate the inverted Y. I get some serious wobble/vibration from my front end if I hit bumps just right at speed. So much I think I am going to loose a fender. Scary :scared:. Well a beefey aftermarket stablizer and replacing the track bar (with another used unit but the joint didnt move like my orignal.) only temporarly subudued the issue. it seems to be back again. All seems tight, control arms, ball joints, tierod ends. I cant figure this out and i have no more ideas... any new directions guys?
