Super mud
- Bel Air Maryland
So I got a 91 comanche that I just redid the system to where the front and rear split. It had a load sensing proportioning valve that I trashed and now has just a single line for the rear with an adj. prop valve and the front line from the master just runs to a Tee. I did the WJ booster and master since the old replacement already leaks. Now my problem is I can't get fluid from the master to even start to enter the line. I've tried pumping the master, pressurizing the reservoir, vacuuming at the bleeders, reverse bleeding at the bleeders and still nothing. At first I didn't bench bleed master, planning the reverse bleed would take car of it. Then later bench bled it and tried everything again. The only time the fluid level ever went down was when bench bleeding it. I've done a full rebuild on my xj where I bled the master and started with a dry system but have no idea whats wrong with the mj. Thanks.
