trail rate this
- Cape Coral, FL
I know there are alot of threads on this subject. I have searched and read them.
I have a 1998 XJ w/ the stock D30 front. The WJ knuckles are front a 2004. I have everything from the knuckle out.
I have some unit bearings from a 98 ZJ. I measured from the hub mounting surface to the rotor mounting surface on both the WJ and ZJ unit bearings and they are the same. I used a digital caliper.
I have read that I need a .25 inch spacer between the knuckle and bearing to recenter the axle u-joint between the ball joints and center the rotor in the caliper.
If they mearsure the same do I still need a spacer between the knuckle and bearing or can I just make a smaller spacer to go behind the washer and nut for the axle shaft to recenter it?
Thank you for all your help.
