alaska3452000@yaho
- Cle Elum, Wa
So heres the problem, i have a 88 cherokee with the 4.0 inline six. I have a 6 1/2 in lift, 33 inch tires, and a few other aftermarket parts, i noticed that the oil pan gasket was leaking so i decided that since i was going to change the gasket i might as well change the rod bearings.....simple enough right? Wrong. I changed both, got everything back together, filled it with oil and attempted to start it up. Now it will turn over but no start. I though it was the battery so i charged it, no good, tested the coil, its fine, changed the coil wire, still wont start, checked all my plugs and connections, there fine. It ran great when i pulled it in the shop now nothing. It will turn over forever, or at least till the battery dies but it wont start up. Anyone ever have this problem? If so what do i do? Im at my wits end with this problem. PLEASE HELP! Thanks for listening to me whine.:rattle:
