xjennyj
- Canadohta Lake, PA
The 4.0 engine in my 2000 wj died but I found a 4.0 engine from a 2001 xj. Will there be huge issues with this swap?
You can't swap the oil filter adapter over. The oil filter on the TJ and WJ block bolt directly to the block on an angle( or no angle.. I can't recall) with no adapter. Also, the WJ may have an accessory hole tapped in the head that the XJ may not have.
Not trying to argue, but it's the same pump according to my NAPA computer...
Look up any XJ from 91-01 and it's the same part number.
now I need to find out what is different about the 00-01 Xj blocks from earlier blocks..
Guess I should have quoted you. I was responding to this.
Just trying to help you out, dude.
