What do you need done? Ive tried to get help on here before either nobodys looking at posts or just to busy to respond. unless you're in their little click. There is a little shop in Roseville that does all sorts of welding and really inexpensive. No Limit Muffler and Fab. They advertise heavily on Craigs List. Josh welded both my Trusses and some brackets . Just make sure you explain exactly how you want it .He will weld your shit good for less the some of the higher end fab shops. No backyard welds either ,talk nice beads with great penetration. Good luck.
I've never welded spiders and I'm booked for time until the next trail run trying to get the rig running. if i get lucky and get a free evening in the next few weeks you could bring the center section over, cleaned of all gear oil, (no brake cleaner, welding that will literally kill you otherwise i refuse to weld it up), and a spool of .035 flux core wire, and a bunch of metal to throw in there, id be down to give it a shot, but the odds of me having even a free night in the next 2 months are slim to none.... and i only got a 110v anyway. I'm sure a 220v would be better for this application...
