Even if it is not the original window, all the wiring should be in place.....just maybe not connected. If it is not hooked up the wiring should be somewhere in the hatch and then you just need a button to turn it on (the wiring for the button should be in the dash). You might also need to make sure there is a fuse in place for the defroster for everything to work.
It's the very first switch to the left of the column. It's tucked in there pretty well...but even still, I would think you would be able to find it. Unless you are just totally blind. But if you were blind, I would assume you do not have a Jeep to go wheeling in.
