the limey
- Torbay, England
Hi all I have a 1998 2.5td VM XJ.I need to know how to connect the vacuum line into the vacuum harness behind the dashboard so I can have control of my heater vents again!
The problem is the main large vacuum hose that comes from the engine bay into the cab has no where obvious to connect onto to provide the direction knob with the vacuum it needs to move the actuators. Where the hell does this pipe connect onto?
The pipe comes in under the passenger kick plate under the glovebox, dont suppose anyone would mind having a look at theirs to see where it connects onto? I assume the connections would be the same on the petrol models.
http://www.cherokeeforum.com/f2/heater-vents-control-vacuum-pipe-configuration-85188/
I have posted pics on here.
Thanks in advance.
Thanks in advance.
