I got this 1/4" steel plate that has these existing rectangular holes it it. Looks something like this.
The holes are about 1/2" by about an inch long. I want to carve out the red areas making the holes bigger.
I could use a hand file but I have a bunch to do and it would take a while.
I tried using a little Dremel grinding bit on a die grinder but I ate through the grinding stone pretty quick.
Is there some sort of cutting bit or cutting tool that could be used to cut that material out of there?
Thanks.
Thanks.
