mitsumotors
- Winnipeg
My 91' xj idles at about 700rpm. this seems a little high to me. does anyone know where exactly it is supposed to be idling and if there is any way for me to adjust it? thanks
somewhere between bubbly and unevenRe: whats is proper idle for a 4.0
mitsumotors said:check my brakes how? what am i looking for?
The TPS on renix models have a lot to do with idle speed. The TPS (on an auto trans) has two sides, the engine side and trans side, and if you've ever had a renix you know all about idle problems and TPS adjustment!lawsoncl said:I can't see how the TPS would affect this, as its just telling the tranny what gear to be in. Aside from checking your brakes as suggested above, I would check that the throttlebody->tranny cable is properly adjusted.
