I currently have 2 hockey pucks per side but now with 33" x 10.5" in place of the previous 31"s I need to increase the stops.
Fenders have been trimmed, pinch seam flattened and I raised the flares to eliminate the carnage I had on the first flex test with these tires on Cleghorn.
The main rub point now is the inner rear area of the fender well, is that an area that could be "re-shaped" BFH style for additional clearance ?
Should I:
A) add another puck (ugh)
B) remove the pucks and bolt in a 3" aluminum stop
C) remove the pucks and install an extended upper stop.
D) Leave it as is and let tire use the rear area of the fender well as a stop?
I have the small diameter upper stops, 1.250 groove diameter with an O.D. of 1.565 which are 3.050 overall length.
Where do the red accordion looking lower bumps I have seen pic of come from, can't seem to find those.
Is that a good option ?
FYI The front springs are Fat Bob Garage 3" which actually yielded a little more than 3" lift.
Stock short arms with the lowers cut in half, extended to 16-1/4" and re-welded with an angle for clearance at the front mounts. They have held up very well using Moog bushings.
This is too much hunt and peck typing for me, I need a beer !
Should I:
