What gives and what should be stocked. 2.0 Steering
88trailcrawler
OC SoCal
Part 2 in a series. Trying to get the XJ to a reasonably reliable trail rig for 2-3 day trail runs. This post focuses on the steering. Sitting on 33's, Ected lockers, 4:56 gears, driving style is light on the skinny, crawl over or go around.
Current steering is JCR 1-ton. Seems to be beefy.
I see they offer a TRE end set, seems that would be a more than reasonable trail back up parts kit.
Running stock steering pump/box bolted through JCR frame tie ins. Seems pre run maintenance/inspection is reasonable preparation.
Questions:
- Does pre run inspection/maintenance of power steering system provide reasonable expectation of trail run performance?
- Would carrying TRE set be a reasonable trail parts kit?
- what else is common trail failure or damage with regard to the steering?
Just noticed all your threads.... :gag:
I would say inner and outer plates for the steering box and spare TREs would be fine.
At least thats what I carry and I feel good about it. My Currie TRE at the pitman arm wears out every two years it seems. I would like to carry a pitman arm too. $20 is cheap insurance and I have seen a few break
