what does this sensor do???
RWKHausSupply
ok I am a little confussed as to what sensors are where, I will say I DO know where the following are, TPS, MAP, EGR, CPS, KNOCK, IAC, O2, and IAT.
On a 90 6cyl AW4...
My issue is that what is down just above the drivers side motor mount on the side of the block, and what what does it do?
Also, IF I need to check the engine \temp sensor, which one is it? I need to replace/check the one for the ECU.
