HollisM16
- Colorado Springs, CO
This sucks...
It was a really slow roll, can't talk about what happened until after the court date (I stupidly called the police to "see if I needed to report it"- ugh). Luckily everyone was okay and all the suspension, tires, and the axles look like they can be removed. Looking at parting it out but I have to see what kind of interest there is first... Here are some specs:
- Front Currie JeepSpeed trussed High Pinion Ford 9" with 4.88's, 5x5.5 bolt pattern, ARB locker, Warn locking hubs, Chromoly shafts, drilled and slotted rotors, 1-Ton over-the-knuckle steering, reinforced lower control arm mounts, driveshaft flange (axle set up for Coilovers, requires fab work to fit regular XJ, OEM width)
- Rear Trussed Ford 9" with 4.88's, 5x5.5 bolt pattern, Detroit Locker, and 31-spline chromoly shafts (has air bump pads welded on, OEM width)
- Rubicon Express Heavy Duty Track Bar and Bracket
- TnT Long-Arm Y-Link setup
- JB Conversions Heavy Duty NP231 J Transfer Case with Super-Short Slip Yoke Eliminator
- 35x12.50R15 ProComp Xtreme A/T tires, 80% or more tread left (5 total, spare has repaired hole)
- Five 15x8 Ion Black 171's, 5x5.5 bolt pattern
- Custom rock rails (very nice but "feet" were welded to unibody)
- Fox 2.0 Remote Reservoir 14" Racing Coilovers
- Fox 2.0 Remote Reservoir Racing Shocks (don't know length)
- JKS Bar-Pin eliminators (upper-rear and lower front)
- Rubicon Express 4.5" super flex coil springs and fixed control arms
- Timbren progressive front bumpstops (fit stock)
- Rubicon Express 4.5" super flex leaf pack with add-a-leaf
- 2" air bumps
- IPF H4 headlights with FatBoys
- After market speakers and head unit (decent, not amazing)
- Throttle Body Spacer (1" from Rusty's)
- Currie Anti-Rock sway bar
- Locking gas cap
- License plate holder for 2" trailer hitch hole
- Official 2000 XJ Manual/Book (the thick one dealerships use to work on them)
- Stainless steel brake lines front and rear
Things that might prove difficult to remove:
- MORE motor mounts
- Centerforce dual-friction clutch
- Yellow-top battery (bumper has to be removed first)
- Custom front bumper (ties into engine cage)
- 6x9 cone air intake (may have been damaged in rollover)
- Bushwacker flares (looked intact but scratched)
- NV3550 Manual Transmission
Honestly, I don't really have a location where all this stuff could be removed, so I would need someone to "host" that for me (maybe for a percentage of the sales?). But then once the axles are gone I have no idea how the vehicle would be removed. Oy... ideas would be appreciated.
Thanks for reading, be safe out there.
-Hollis
- 2" air bumps
- Locking gas cap
- MORE motor mounts
-Hollis
