bowzone_mikey
- Prince George BC canada
Ok then 95 sport 4x4 AW4, 247000 KMs (153 000 Miles)
I was driving to work today and my tranny just went into "saftey mode" ... wouldnt shift out of first, I pulled over ... wouldnt shift into reverse, Turned the Jeep off .. waited 15 seconds turned on and drove fine again the rest of the way to work
... I installed a cooling fan switch today and I ran it off of fuse #2 (Radio, Cig etc... switched source according to owners manual )using one of those Add-a Circuts . When I had the jeep off I pulled the add a circut out and replaced the orginal fuse. I have since moved the add a circut to fuse space #4 (according to manual, Flass to pass, constant powered)
Tranny control unit? possibly on its way out ??? I have never heard of such an instance... If so .. are all years compatible with a 95 ... the local JY has a couple of sweet newer Xjs in
WTF? Over?
***a side note Pobally not related but could be relevent,
Last week I had the Tranny replaced with a lower milage used one(the oil was good and red), while the tranny was out I had the cooler lines replaced and cooler flushed, All done by a shop that knows their stuff and is extremly reputable here, however not alot of expiriance with the Cherokee Trannys, Mine was the 3rd XJ that they could think of.... I suspect because the AW4 isnt that problematic of a tranny typically.
The original had lost 2nd and was losing 4th and was also puking out the front ....
WTF? Over?
