footdale
- Albuquerque, NM
This water pump (allegedly new) was installed early 2007 by a shop. I never had any cooling issues until about 3 months ago when the radiator started leaking. The coolant was a nasty brownish/red color, but figured it was that way because it hasn't been touched since the pump replacement. I thought I did a good job flushing the system out and replacing everything per the :
: recommendations in the 1000s of overheating posts I read through.
After the job, I noticed that the coolant almost right away reverted back to the rust color. I didn't really care until I started having overheating issues the last few weeks. After draining the system, pulled the pump and found that all the impeller blades have severely eroded away.
I've talked to some people and they've never heard/seen something like this before, at least for a part that was new in 07. Is there anything I should look at to make sure this doesn't happen again? I'll probably do another flush in the near term if there is any remnant material in there.
