Warn Winch Rebuild. Quick question.
Lucas
ZOO YORK CITY
Im relubing the used XD9000i I got for Xmas. Warn specifies using aeroshell 17 for greasing up the geartrain because of the high moly content. Do I have to use this stuff, or will a general moly grease I get at autozone work?
Use the Aeroshell 17. It is a high heat/high viscousity aviation grease for aircraft landing gear. Go to a local aircraft maintenance place and they usually sell it in tubes about the size of a caulking gun tube. Should be about $10. That will be enough to do two rebuilds.
