Wanted; WJ/TJ 4.0
I have a 99 4.0 with only 119k miles. this is the year you don't have to worry about the head problem as well. Clean motor that runs strong. Shoot me a PM or call/text if interested. Motor should work for your application, just confirm it. Thanks, Jeff 302-five 3 zero-1304
That motor should be a direct swap. I would jump on this Neil, check his part out thread it looks to be coming out of a clean, well maintained truck. I would get it in a heartbeat if I had the room just to store it.
XJ wont swap over to WJ, the WJ uses the "clean slate block" design.
Wonder.. check out CL. Guy parts TJ's and a newer one would have the correct block.
