Wanted chrysler 8.25 yoke
There were quite a few different yoke options offered. What year and a picture would be great. I might have one for ya.
here is what you had 89xjgrey
http://www.quadratec.com/products/52425_09.htm
this is what i had/ need now
http://www.quadratec.com/products/52425_10.htm
no bit deal its my own fault for not knowing what i needed. Anybody wanna buy a yoke like the first one pictured that has been milled down to accept u bolts?
i think the major difference is the length. I am going to try and put it on tonight(so i can still go wheeling this weekend) and see if it will work. I didnt put it on last night because i needed a new pinion seal and no parts stores were open.
8.75 have two different yokes, and im unsure of the year splitting the two, but the biggest difference is the length of it. one should be 2.75'' long and the other 3'' long. Determine which one you have, then order from the link. price on this is okay, ou could prolly find one much cheaper at boneyard, or even your local light/heavy truck shop may have one. NAPA is pretty good about driveline stuff. forget carquest/autzone/advance. Maybe oriely's but wayyyy to much there. as we all know, forget the dealership. anyway, id just order one from here if i was you, there usuualy spot on here, and they're reallllly good if they send you the wrong stuff. Its happened to me here once only, but ive spent a shitton of money here. I pretty much stock parts in my garage, things that commoney go out...(although ive been looking and I ahve no yokes for you, sorry dude.) anyway, heres the link:
http://www.jeep4x4center.com/jeep-axle-differential-parts/chrysler814-rear-cherokee.htm
Ok, from what I have seen there are more than two different yokes for these axles. I have three different ones here, please post or send some detailed pics of your original and I will see if I have the one you need.
i will get some pics as soon as possible and the two i found are pictured and by the sounds of things the shorter one is pre 96 and the longer is 97 plus.
and 85xjwoody mine looks identical to the second one pictured. Can try adn get you some pics if you need more.
thanks
thank you and most bone yards around me wont seperate them from the axle :wierd:
